Zum Hauptinhalt wechseln
I want to upgrade my RAM and Solid State Drive in this laptop
Please help me I want Change my RAM and ROM
Update (10/28/23)
HP Pavilion Ryzen 5 Hexa Core AMD R5-4600H - (8 GB/512 GB SSD/ Windows 10 Home/4 GB Graphics/NVIDIA GeForce GTX 1650TI/144 Hz) 15-ec1025AX Gaming Laptop (15.6 inch, Shadow Black, 1.98 kg) this is my laptop
I want to upgrade both Read only memory and Solid state device to 16 gb ram and 1 tb ssd
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hi @boyuk,
What is the full model number and product number of the laptop as shown on the information label on the bottom of the laptop?
FYI ROM means Read Only Memory and is not used to refer to an SSD
SSD means Solid State Device which is memory that can both read and write
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @boyuk
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.31 to view the procedure to remove/replace the memory modules.
Go to p.30 to view how to remove/replace the SSD.
At the top of each of the pages you'll find the part numbers for the components.
Search online for 937236-855 to find suppliers for the memory module. You'll need 2 as this part number is only for an 8GB module i.e. 2 x 8GB
Search online for L72515-001to find suppliers for the 1TB SSD. Note: searching online it appears that your laptop model only supports PCIe Gen 3.0 x 2 whereas the 1 TB SSD part mentioned requires PCIe Gen 3.0 x 4, so it will work but it will only work at the Gen 3 x 2 speed.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Boy Uk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 771
