Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
How do I reset a disabled iPod Touch without a computer?
My iPod Touch 4th Gen will not enable. I forgot the password. How do I reset it without a computer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 316
68 Kommentare
Hold down power and home button until logo shows up and will reset to factory downside is all data will be deleted
von
I don't have a computer
von
von
You can't do it without a computer
von
i have ipod 5 touch does it work on this
von
63 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
17 Antworten
Gewählte Lösung
There is no way to do that, unfortunately. You have to put the iPod into DFU mode and then use a computer to restore it. I would suggest trying to find a buddy who will let you use their computer. To DFU the iPod, have it plugged into the computer, hold the lock and home buttons until the device shuts off, wait five seconds, and then release the lock button while still holding the home button. A message should then pop up on the computer telling you that the iPod is in recovery mode and that you have to restore it. Let me know if you have any questions
War diese Antwort hilfreich?
Bewertung 76
56 Kommentare:
this didn't hepl tell me an alternative method if possible
von
@abhisek neymar, just like Jason rightly answered, there is no alternative method. "There is no way to do that unfortunately. You have to put it into DFU mode and then use a computer to restore it." Follow his advise .
von
What happens if that does not shut it off
von
This happened to mine. I did exactly what he said and it is restoring as I am typing. Thank you so much! This helped and I can't wait even tho it will take an hour or so thanks so much!!(:
von
what if a message pops up saying there's an error occurred (3194) ???????????
von
51 weitere Kommentare anzeigen
Requirements :
1. A computer (Mac or Windows)
2. An Apple USB Cable
3. Your iPod
Method:
1. Connect your iPod to a computer running iTunes using the USB cable
2. Make sure your iPod is turned on, the hold both the Home and lock buttons simultaneously and hold for 10 seconds
3.On your computer go to iTunes and click "Restore iPod"
4. Wait for iPod to restore and enjoy!
Hope this helps
Bewertung 14
13 Kommentare:
I get a message that I have to restore the ipod before using it with itunes but when I click ok, the restore ipod screen goes away. How can I keep that screen up to restore it?
von
If i restore my ipod touch 4 will it delete my apps, music, pictures, etc
von
What if u don't have an apple account how do we do it then it will not let me I try using my aunts account and it will not let me
von
but windows doesnt recognize my ipad it keep saying usb not recognize
von
What if you have a chrome Book and not able to connect to iTunes i would ask my mom but she would say no so what do i do??
von
8 weitere Kommentare anzeigen
all you have to do is hold the power button and home button at the same time for ten seconds then let go of the power button but keep holding on to the power button for 10 seconds. then it should restart.
Bewertung 8
4 Kommentare:
i tried that before but when i did it still popped up saying iPod is disabled connect to itunes
von
it is not working
von
Let go of the power button but hold the power button on? That does not make sense
von
I know right
von
If you don't have one then you'll need to buy or get a lend of one I'm sure you no someone with a USB cable
Bewertung 6
1 Kommentar:
Would iMac,MacBook include a usb cable
von
I don't have a computer and I forgot my password and the people I do know don't have a computer
Bewertung 5
3 Kommentare:
As I stated before you need a computer to complete this process. Try your local library, apple store or best buy.
von
wow "the people i DO know" makes it sound like you live in a cave and the only people you DO know are the ones who you haven't eaten yet.
von
verizon stores will unlock or reset your ipod for free! u dont need a verizon account!
von
yes unfortunately you cant do anything without the computer i tried everything and still does not work. my charge bars are bent so it does not work i will try suggestions if any one has some very appreciative
Bewertung 4
1 Kommentar:
verizon stores will unlock or reset your ipod 4 u for free, u dont have to even have a verizon account
von
Well basiclly you press the sleep wake button and home button for 10 secs till Apple icon appears. Then let go of the buttons. Hope this helps!
Bewertung 3
3 Kommentare:
that didnt help at all i tried a couple of times but it didnt work ):
von
i found an ipod touch 2nd generation its has a password and i need help unlocking it.how do i do that without a computer
von
Close, you need to continue to hold the home button after 10 seconds and releasing the lock button. That is the difference between a forced reset and putting it into DFU mode. Alisha first off you should contact Apple and try to return the iPod. I am sure someone is missing it
von
i found a ipod touch, but ican't to delete the id and password.
Bewertung 3
1 Kommentar:
Take it to Verizon they will unloOk or reset it 4 free, NO verizon account needed, takes 10 min
von
Can I plug into another phone using iTunes app then do the reset function? ?? Would that work
Bewertung 2
Can someone help me unlock my iPod touch 5 i got it on letgo serial number is dj6kt0cff4k4 can someone help me out
Bewertung 2
IPod 5 no enciende que se le hace
Bewertung 2
well you get your usb cable and hook it up to an outlet than you take a pic then you will go tot he lockscreen and slide up so on the left hand side you will see a flash light Image than right next to it on the right there is like a watch images than you will click on that then you press the sleep/awake button then it will say slide to sut off under that it will say cancel you pres on cancel then you wil press the home button 2 times really face hope this work cause it worked on mined
Bewertung 1
3 Kommentare:
What?Wheres the correct spelling?
von
i've erased my ipod, version: 421(8c148) model:MB52LL
von
Apple iPod 7.0.4. Serial number-ccqm345gffcj. Says connect to itunes
von
If you don't have a computer then go to the Apple store, and use one if those. They will let you use it.
Bewertung 1
how do i reset a ipod if it wont go into dfu mod it just shows the apple logo
Bewertung 1
Get my ipod said disabled CONNECT itunes how get off please help me
Bewertung 1
I know how you feel, my dad will recover it, but try to find a nearest Apple store, or use your teachers MacBook or iMac! Hope it helps! I’m in 5th grade so this should help! :)
Bewertung 1
1 Kommentar:
Apple store will let you borrow computer
von
How do I unlock my ipod without a computer
Bewertung 1
Antwort hinzufügen
kato wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 27
Letzte 30 Tage: 108
Insgesamt: 484,279
