Zum Hauptinhalt wechseln
Repair and disassembly guides for Kenmore Microwaves.
door handle broke off, how do I replace it?
My Kenmore microwave Model #790-80329310 door handle broke off, how do I replace it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@mabelmeadors, I haven't had any luck yet locating a guide or a video
Official Frigidaire 5304491623 HANDLE
Here's the gist of the answer.
Hello Fred, Thank you for the question. You will need to remove the inside door panel with a putty knife or flat tool to expose the screws that hold the handle in place. We hope this helps!
Provides a reliable replacement for broken or damaged microwave door handles. Bild
Produkt
5304491623 - Frigidaire Microwave Door Handle
$78.99
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Hi @mabelmeadors,
Just to add to the answer, here's a video that in general terms may help.
You may not have to remove the door from your oven but the removal of the inside door panel is usually the same.
Note: So as not to confuse you, your microwave oven is either a rebadged Frigidaire model or a made for Kenmore by Frigidaire model, as it is comprised solely of Frigidaire parts, hence the video showing a Frigidaire microwave oven
von
Antwort hinzufügen
Mabel Meadors wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 947
