Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
You could try to let it run completely empty so that it switches off, then charge it and switch it on again.
If that doesn't help, you could try to access the boot menu and clean the cache partition. And if that doesn't help, you can try a factory reset via the same menu.
Hi @sami36007,
Does it still do this if the charger is connected?
Does it do this if you start the phone in safe mode?
Has the phone been dropped or gotten wet at all?
von jayeff
von Spot
