Zum Hauptinhalt wechseln
The 6th generation of the Moto E smartphones. Model numbers XT2005-1, XT2005-3, XT2005-4, and XT2005-5.
14 Fragen Alle anzeigen
What did I do wrong?
I thought I could take the phone apart and put it back together again but now it's stuck in some sort of boot loop and if it isn't in the loop I just see N/A in the corner. Did I break something or did I just forget to plug something back in?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@green36821 just to clarify, there were no issues with this phone prior to the disassembly. It functioned as should and now it does not. If that is correct, it sounds like there is either something that is not connect right. You will have to open it up again and check all the connection. Make sure they are properly seated and that there are no bend or broken pins.
It is also possible that this is a software issue. Which is less likely since your phone worked before, Let us know what you find out.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
so i took it all apart looked at everything and nothing seemed broken and its all plugged in but its still doing the same thing. is there anything else i should try or should i bite the bullet and bring it to a shop?
von
Antwort hinzufügen
Green wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 69
