Zum Hauptinhalt wechseln
Das am 16. September veröffentlichte "kleinere" Flaggschiff-Smartphone von Apple verfügt über ein 6,1 Zoll ProMotion-OLED, ein rückwärtiges Kamerasystem mit drei Linsen, 5G und eine neu gestaltete Dynamic Island um die Frontkamera und die oberen Sensoren. Es ist der Nachfolger des iPhone 13 Pro.
hello I have iPhone 14 keeping restarting
hello i have iphone 14 keeping restarting
panic(cpu 2 caller 0xfffffff05dc10fdc): SMC PANIC - ASSERTION FAILED: target/d27/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40
S.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0
F.sensor array 0 is 0x0
- Misc(2) OUTBOX1 not ready
RTKit: RTKit-2413.42.1.release - Client: AppleSMCFirmware-4257.42.2.d27.REL
!UUID: fab53dca-5d4c-3354-a473-f8e57aa561cc
Time: 0x000000010da8c27c
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@arvind4366, It looks like we haven't got that particular error logged in our Kernel Panics Wiki page yet, but over on repair.wiki, they've got a listing for it.
That's a curious one, as it's not a failure I've personally seen before; the only time I've run into a charging coil failure has been from someone who was doing a rear glass replacement and damaged it.
Anyway, I don't know what might have gone wrong with your phone, but at this point the best advice I can offer is to replace the wireless charging coil and see if that fixes the problem. There don't appear to be any guides available to show you exactly how to replace it, but I'm guessing if you remove the rear glass cover it's mounted on, it should be pretty straight forward to figure out how to replace it. This guide will show you how to remove the rear glass.
iPhone 14 Rear Glass Replacement - iFixit Repair Guide
Luckily, you can also buy that charging coil directly from iFixit as well as other sites like Amazon, eBay and AliExpress.
iPhone 14 Wireless Charging Antenna
Of course, the other choice is that you could replace the entire back panel and thereby sidestep the entire issue of how to replace the coil by itself. You can find those on Amazon and other places. If you go this way, make sure the part you choose specifically says it comes with the charging coil. I think this one fits the bill.
Amazon.com: Rear Back Glass Replacement for iPhone 14 with Middle Frame and Side Key : Cell Phones & Accessories
Good luck and let us know how it turns out!
Note to @flannelist: I've added the 0x40 0000 code to the Kernel Panics Wiki page since it's documented on repair.wiki now.
Replace a damaged or malfunctioning internal inductive charging coil in an iPhone 14. Bild
Produkt
$54.99
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
as u said i have removed backglass n just refitted problem seems to be fixed.. lets see i will keep for somemore time playing a nice songs n check , thank u so much @Jerry Wheeler
von
@dadibrokeit Duly noted :)
von
Antwort hinzufügen
ARVIND wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 44
Insgesamt: 1,019
