Where is the battery
I can't find the lithium rechargeable battery on these headphones. Is it in the right or left ear piece. No info on Bose site. Runtime is down to 20 minutes
Ist dies eine gute Frage?
@mlkirwan do that on the LEft side. Remove the ear cushion. you should find 4 screws. Two standard Philips and 2 Bose proprietary screws. you can use a rotary tool to drill them out or try a T5 security bit. Now you should have access to the battery.
War diese Antwort hilfreich?
Great answer! Got the battery out but there is no product designation? Does anyone know the battery number is?
@mlkirwan interesting that Bose thinks it needs to keep this a secret. Here is a quick fix for that. Measure teh length, with and height of your battery in mm (millimeters0 and let us know what you find out.
The model II uses a AHB571935PCT-01 3.7V 350mAh Those values apply to your model as well.
So did you find the according battery model for the Soundlink On-Ear? Or is it compatible with AHB571935PCT-01 mentioned above?
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 192
