Zum Hauptinhalt wechseln
Der Nintendo Game Boy Advance wurde 2001 veröffentlicht. Die Reparatur erfordert nur gängiges Werkzeug und keine Hitze.
Very dark screen when playing games
I’ve just purchased a second hand game boy advance and it’s quite hard to see the game due to dark screen. I’ve tried the usual holding select and clicking left/right but no good. Also found the pot behind the serial number but no good unless I need a very small screwdriver but not sure. Any help greatly appreciated
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The Game Boy Advance doesn't use a backlight, which can make it hard to see the screen in low-light conditions. If you are willing to take apart the GBA and use some tools, there many backlight modifications on the web that can be used to help install a backlight into your GBA. But you must keep note: by installing a backlight mod into the GBA, you must do it correctly, as you could cause damage to your GBA if done incorrectly. You will need some tools, and a soldering iron, for the task.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Lee Wheller wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 68
Insgesamt: 2,693
