Hi @andreasgaede
I realize that you removed the battery and tried starting on the power only but try a full power refresh to see if this works.
This is different because you forcibly remove all the power from the motherboard in the hope that this will reset the BIOS software in case it has become corrupted.
It seems like this has happened to your laptop as a prolonged hi-speed fan on startup generally indicates a problem with POST (power on self test). POST occurs when the laptop is first turned on and the BIOS checks that all the hardware is OK before it starts booting into the operating system (Windows) i.e. Start →POST→logo on screen→boot into Windows
The procedure is to disconnect the charger if it is connected, open the laptop and disconnect the battery from the motherboard, (you don't have to remove the battery, just disconnect it) then press and hold the Power button operated for a full 30 seconds and then release it.
Doing this drains all the power from the motherboard which resets the BIOS software back to its factory default condition as you are forcing it to try and turn on, which obviously it can't do because there is no power connected to it.
Next reconnect the battery, reassemble the laptop, reconnect the charger and check that the laptop is charging OK. If it does allow it to charge for a few minutes and then try turning in on.
If it turns on OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been reset. Once you correct the date and time the message won't appear the next time the laptop is started. Also any user definable settings in BIOS that you have changed to suit whatever operating requirements you wanted, will have to be changed back again as well.
If it still doesn't work you may need the schematic to find out what's wrong. (I think that the motherboard is an Compal LA-B111p, check what is shown on the motherboard to be sure)
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
6 Kommentare
@andreasgaede your laptop is a Lenovo Y70-70 Touch? what have you checked and what have you tried to fix this?
von oldturkey03
Thank for your replay. I tried a lot but nothing helped.
# I wait until the battery was empty and started it with pluged power supply.
# After power button I pressed F2 and F12 to try to enter the Bios setup, without success
# I checked the connection of the LCD cable on both sides LCD and Mainbord side.
# I tried an external Display via HDMI, but there was nothing shown
# I removed teh Battery and tried to star just with power supply
# I tried to start with removed RAM modules and also with removed HDD
All these things doesn't work at all. So Ihave no further Idea
von Andreas Gäde
@andreasgaede
Have you tried pressing the Novo button and checked if the laptop started at all?
von jayeff
What is the Novo button?
von Andreas Gäde
@andreasgaede
See Item #8 on p.2 & p.1 of the user guide for the laptop model you selected to find out what the Novo button is used for and where it is located.
von jayeff
1 weiteren Kommentar anzeigen
