Zum Hauptinhalt wechseln
A 17.3” gaming laptop by Asus with an Intel 3rd generation Core i7 processor, dual-fan cooling mechanism, and Nvidia 3D LightBoost technology.
How to fix lcd with 1 green vertical line.
how to fix lcd with 1 green vertical line. is it possible if that occur by software failure or it must be the hardware?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@amosdaniel94668 a single line will be a hardware problem. If it iis about one pixel wide it is a TAB error and if it is wider it is a data issue from the driverboard on the LCD. Without seeing it and going by your description alone, this is an LCD error.
Of course, you can always validate this answer by connecting an external monitor. If that does not display the same line, you know it is your LCD.
Time to replace it or to learn to live with that line,
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Amos Daniel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 58
