Zum Hauptinhalt wechseln
An Auto Reverse, Dual Cassette Deck released by Denon in 1999. Discontinued in 2003.
Denon DRW-580 will not record audio
So I have a Denon DRW-580 Cassette Deck that is fully functional apart from, recording.
The audio meters show sound activity, the tape cassette spins when the Record and Play buttons are pressed, but on playback, it is completely silent, there is no audio being recorded on to the tape.
Any ideas on what could be causing this?
Any help would be greatly appreciated.
Thank you.
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
@prim82680 has this ever worked for you? Anything happened to it? You made sure that you still have the record-tab on the cassette? Does this go for both sides? Where are you recording from?
von
Thanks alot for your response and queries.
I was given the unit by a friend some years ago who assured me, it was working fine the last time he used it.
However, I have had it for a number of years also, and although I have used it throughout this time, it was only for playback and to digitalise my old tape recordings.
I have never used the Record function until recently, this is when I discovered the anomaly.
Nothing untowards has happened to the unit, ie, knocked, dropped, or a stuck cassette, at least not while it's been in my possession.
The inserted cassette is a new blank TDK. While it is recording I can see clearly that the level meters are responding to manually lowering and raising the record level with motion to the beat, and spindles are spinning smoothly.
I don't recall trying to reverse record, this is something I will try.
I am attempting to record from an RME Fireface 400 audio interface, via the headphones output.
Hope this helps.
von
I would first check to see if the signal is getting to the tape head. The Denon double-well decks are wonderfully laid out so you can easily see the connections for both playback and recording. open the case and you will see cables running from the transports to the board. Both playback and recording cables are marked. Identify the recording cables. Unhook one to test. Put the deck in record mode (preferably with a 1khz test tone at 0dB) and see if your multimeter measures AC voltage at the pins where you disconnected the cable. If you have no signal you'll have to go further back in the signal path. If you have signal that means the tape head is not receiving the signal. There could be broken wires close to the head where it has to move up and down. Do both transports fail to record? That points to a problem further back than the tape head. Hope this helps.
von
Einen Kommentar hinzufügen
1 Antwort
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hi @jshood.
Thanks for your input.
What you have suggested is definitely something I will look in to, though I have since returned it to storage.
Thanks again for the advice.
Regards.
Prim.
von
Antwort hinzufügen
Prim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 225
