Model FGHB2868TD2 Ice Maker Not Getting Water
My ice maker quit working and the ice cube tray is empty with no water in it. I can run through the diagnostic tests to get the tray to dump and the thermister is reading 0 degrees. I removed the quick connector on the green water line on the back of the fridge going to the ice maker and ran the test 55 to add water to the ice maker and I do not get any water so I don't think this is just a frozen line. With the green line still disconnected I swapped out the electrical connector on the yellow solenoid for the water dispenser and put it on the green solenoid for the ice maker. When I pushed the lever in front for the water dispenser I then got water out of the green line to the ice maker in the back of the fridge so I think the solenoid is good. I also tested voltage on the green and yellow plugs when pressing the water dispenser lever and got 117VAC. Anyone know where to go from here or what to check next?
Ist dies eine gute Frage?
