Zum Hauptinhalt wechseln
Das Lenovo IdeaPad 3-15IML05 ist ein 15,6-Zoll-Laptop für alltägliche Computeraufgaben. Es ist mit Intel Core Prozessoren ausgestattet. Die Modellnummer des Geräts lautet „15IML05“.
nvidia mx330 43 error and I get 30 fps on games using intel uhd
when i bought my laptop, i used to play games perfectly but suddenly after 2 years, the nvidia card sometimes worked and sometimes nope until i reinstall the driver, but those last days, i get the 43 error, idk how to fix it even i reinstall it but when i tried an older version my pc crashes and turn off, then it turned on again. I hope someone can help me also i tried to ignore the problem and play using intel uhd graphics but the games work with 30 fps instead of 60fps
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To eliminate software/driver error click below
Display Driver Uninstaller or DDU
It is freeware and completely removes all traces of the video driver. It is important to remove all traces as there may be some corrupted files or settings. A Windows normal uninstall does not remove everything, especially settings.
Follow instructions very carefully. Read them over a number of times before doing anything.
I have used this software many times over the years with much success.
If that doesn't fix it I would guess it is a hardware issue.
Tutorial
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
where do i find the instructions?
von
Hi @haitammorchid
It is on their websuite. Click on "Tutorial" (coloured blue) above.
von
Antwort hinzufügen
Haitam Morchid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 596
