Zum Hauptinhalt wechseln
Anleitungen für die Wi-Fi-Version des iPad mini 5 - Modell A2133. Das iPad mini 5 kam im März 2019 auf den Markt und ist der Nachfolger des iPad mini 4.
Digitizer not working after replacement
I bought a replacement Screen and digitizer The screen works great but the digitizer docent some spots don't register on the left and right in portrait mode and in regular mode I can't see ANY damage The connector looks good. Is there Something you have to cover or is it apple's prioritization
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
don't have the original screen but the old digitizer worked perfectly except it was cracked and the display
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You didn't mention if you had cleaned the connector with some 90% or higher isopropyl alcohol, but other than that it looks to me as though you've covered pretty much all of the diagnostic bases.
At this point I would communicate with the seller of the replacement screen on the issues you're having with it and see about getting a replacement, especially given that you didn't have digitizer issues with the original screen.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks I cleaned it am waiting for it to dry. let you know if it works.
von
Antwort hinzufügen
Alistair moran wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 216
