Zum Hauptinhalt wechseln
The 4th generation Surface Laptop, released in April of 2021, shares the same body design as its predecessor, with upgraded internals including Intel 11th gen and AMD Ryzen 4000 processors, more RAM, and upgradeable SSD storage.
Overheating! Can’t install New Windows
The laptop is overheating whenever i try to install the windows, deleted the previous windows as it was corrupted. Now in order to make the laptop work i need to install new windows in it, but it keeps overheating and shutting down after a few minutes of installation. Is there anyway that i can stop that from happening?
And, if someone knows where can i get a new motherboard for it, please let me know. Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It might not be the motherboard. You might want to replace the thermal paste in the device. Follow this guide, and then install new thermal paste onto the die of the heatsink Microsoft Surface Laptop 4 (13,5") Kühlkörper und Lüfter tauschen
Make sure not to strip any screws, as that could cause the heatsink to not have direct contact with the CPU. You will also want to be very carefull applying thermal paste, and make sure to cover the whole die, and not to scratch it.
Good luck fixing your device!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Syed Shoaib Ali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 224
