Zum Hauptinhalt wechseln
A1418 | EMC 2889 | Ende 2015 | 1,6 GHz Dual-Core Intel Core i5 oder 2,8 GHz Quad-Core Intel Core i5. Erscheinungsdatum 13. Oktober 2015.
audio jack not working
repairing the audio jack - what do i have to remove to access and repair the audio jack. It no longer provides an audio signal to headphones plugged into it.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would just get a USB-A DAC adapter like CableCreation USB Audio Adapter as replacing the iMac headphone port is a lot of work as you need to take the logic board out to gain access to the port which is glued to the case so you can get a heat gun to it to soften the glue. Follow this guide iMac Intel 21,5" EMC 2889 Logic Board austauschen and here’s the needed part Headphone Socket and Cable
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for providing bot a practical answer (which I will go for) as well as a link to the full solution which looks a bit difficult for me
von
Antwort hinzufügen
Gordon Webb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 212
