Zum Hauptinhalt wechseln
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
20 Fragen Alle anzeigen
My phone speaker is not working
my phone speaker not working
Ist dies eine gute Frage?
Bewertung 9
2 Kommentare
My phone battery is not charging
von
My phone blinks
von
Einen Kommentar hinzufügen
13 Antworten
Hilfreichste Antwort
There are a few things you can try first:
  • Restart your phone. This is often the simplest way to fix minor problems.
  • Check your volume settings. Make sure that your phone's volume is turned up and that you're not in silent mode.
  • Clean the speaker grills. The speaker grills on your phone can get clogged with dirt and dust, which can block the sound. Use a soft brush or cloth to gently clean the speaker grills.
  • Update your phone's software.Sometimes, software updates can fix bugs that cause problems with the speakers.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
It's helpful
von
Here are some quick fixes for a non-working phone speaker:
  • Check the volume: Make sure your phone isn't muted and the volume is turned up.
  • Restart your phone: A simple restart can often resolve software glitches.
  • Clean the speaker grille: Dust or debris can block the speaker. Use a soft brush to clean it gently.
  • Test with different audio sources: Try playing music, videos, or making a call to see if the issue persists across all apps.
If these don't work, the problem might be more serious and require professional repair.
Bewertung 1
Well check out the following: https://www.youtube.com/watch?v=vAG8B0Dx...
Bewertung 0
One speker not work
Bewertung 0
My phone speaker not working
Bewertung 0
My mobile does not work
Bewertung 0
Mobile speaker is not working
Update (06/25/24)
Bewertung 0
1 Kommentar:
My mobile is not working
von
Hello guys,
my phone doesn't vibrate, how can i solve that issue please.
TECNO CAMON15 premier.
Bewertung 0
1 Kommentar:
Well Checkout the following video it might help you in fixing the issue:https://www.youtube.com/watch?v=W0-_BKzz...
von
Check volume levels
Reboot your device
Adjust the app sound settings
Clear the speaker
Bewertung 0
Charger not save
Bewertung 0
Bewertung 0
Speaker not warking
Bewertung 0
Screen is not touching
Bewertung 0
Antwort hinzufügen
asfaw kefyalew wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 34
Letzte 30 Tage: 121
Insgesamt: 2,216
