Zum Hauptinhalt wechseln
Whirlpool-Wäschetrockner ohne Abluft.
Dryer is making squealing sound YWED7990FW
It’s making loud squealing sound, I believe I need to get to that rollers or it could be a bearing? Is there a guide available to show to show what I need to remove in which order to get to the rollers? I have the video with sound
https://share.icloud.com/photos/0dfAQ1qq...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @amar60544
Here's a link to a video that shows how to remove the rollers in your dryer.
If the rollers are faulty, search online for WPW10314173 to find suppliers that suit you best.
Here's a link to a parts supplier that is useful if other parts are required.
Search through the list to locate the wanted part. Once you find it you will see the manufacturer's part number for the part. Search online for the manufacturer's part number only to find suppliers that suit you best.
Supports the dryer drum, helping it rotate smoothly while preventing noise during operation. Bild
Produkt
WPW10314173 - Whirlpool Dryer Drum Support Roller
$16.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks, I was able to use that video to get to the front rollers and clean them, lots of things stuck in them because of which they were making noise
von Teilen
Antwort hinzufügen
Amar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 26
Insgesamt: 437
