Zum Hauptinhalt wechseln
The DJI Mini 2 is a small drone that was made in 2020 by DJI. The DJI Mini 2 has 4K/30fps video and 10km 720p/30fps video transmission.
My dji mini 2 will not hover in place keeps drifting right or left.
DJI mini 2 will not hover in place even when there is no wind. Have tried all the recommended solutions on this site (recalibration compass, IMU, checked propellers and casing and nothing visible.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Check propellers again, mine had very small dent on 1 propeller from bottom side on the end, around 0,5mm not visible but I could feel it by touch. Simply sand it very gently with grit 400 sand paper to get it smooth and voila.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I've flown with damaged props and it still was very stable but only extra noisy
von
Your circumstantial description is somewhat limited ;
  1. did you take off after the spoken message "home point updated" ?
  2. did you verify how many satellites were detected once it started to drift ?
  3. is your DJI FLY set for 'return home' or 'stay in place' if connection with RC is lost ?
It may be that gps module has a technical problem, it is not so difficult to replace because it is a seperate pcb in the top half of the Mini2. It helps if you have some repair experience though. The costs are about 35€ if I recall well, for the GPS pcb I mean. Just make sure you order exactly the same pcb number as original, like in this example "PP 002025.02"
See Aliexpress.
Bewertung 0
Antwort hinzufügen
Tony wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 181
