Zum Hauptinhalt wechseln
The eighth generation of the Mitsubishi Lancer.
lights on the cluster flicker when I try to start it it all goes dead
I have a question hopefully some one can help me figure this out ! 2007 Mitsubishi galant the ignition was ok till now now I try to start it the lights on the cluster flicker the when I try to start it it all goes dead .the battery is fully charged don’t know where to start !! Does anyone had that problem with the ignition and knows how to fix it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @michaelgiovanni
Looking at the images of the starting circuit and some of the cluster lights, it seems that the only common factor may be a faulty ignition switch.
Once the ignition is turned to the start position the starter motor should begin to turn over as it is basically direct wiring from the switch via the transmission switch to the starter.
(click on image)
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Michael Giovanni wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 67
