Zum Hauptinhalt wechseln
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
PSP 3001’s Won’t Turn On, but the Battery Heats Up
I bought a used Psp off of ebay to repair it. It didn’t come with a battery so I bought a replacement with the correct voltage. After fully charging battery and placing it in psp, I turned it on. The psp begins to heat up, but the console still doesn’t turn on. What can I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would recommend getting a replacement battery. If the battery is heating up it could also be a possibility that there is gas forming in your battery which will cause bloating. For your safety I would recommend removing the existing battery and try purchasing a replacement one.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Extermz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 42
Insgesamt: 342
