Zum Hauptinhalt wechseln
A1418 / EMC 3068 / 2017 / 2,3 GHz Dual-Core i5 Prozessor. Erscheinungsdatum Juni 2017.
20 Fragen Alle anzeigen
Can't find hard drive!
I have a 2017 21.2" imac. had 256gb hard drive which after 6 great years of service...died. I bought the ifixit kit and all the steps to get the screen safely off were successful. However there is no hard drive, Here is image of aerea where hard drive is supposed to be... its empty! what gives? I don't even see a loose SATA cable? This machine has never been opened before today
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Since the HDD holder is empty, we have to assume that you have the model with a SSD that you can find by removing the logic board.
I've attached a picture to give you a look at the back of the logic board, in the tutorial iFixit used the model whitout ssd connector but yours will have it
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Here’s a guide of a similar model iMac Intel 21,5" EMC 2889 Blade SSD austauschen
Be aware you will need a SATA/Power cable for the SATA drive if the drive is not present. Double check referencing this guide iMac Intel 21,5" EMC 3068 Festplatte austauschen
von
Antwort hinzufügen
errol segall wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 117
