Zum Hauptinhalt wechseln
The Dell G15-5510 stands apart from the 5511 by its 10th Gen Intel 10200H processor and GeForce GTX graphics. It hosts a wider range of ports, and it built with a sleeker design without sacrificing much performance.
Wire in the way of 2nd SSD slot
I'm planning to put an M.2 2280 in the 2nd SSD slot, but there's a wire in the way of it. Where's a good place to put the wire?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Can the m.2 go over the wire? If not, then I would just peel the tape attempt to route it around the drive. It looks like it has enough slack to go around the end but only you could verify. Look at the attached picture for what I mean
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for the advice. I put it in today and it did go over the wire without any sort of bend or trouble.
von
Antwort hinzufügen
Tufty 13 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 77
