Zum Hauptinhalt wechseln
Die Sony PS5 wurde im November 2020 veröffentlicht und hat viel bessere Graphikleistungen und einen innovativen neuen DualSense Controller. Das neue Farbschema hat was von Weltraum und ist eine bemerkenswerte Abkehr von den alten Designs der PlayStation.
Which power supply to get: 400DR or 400ER?
Hi,
I am looking to replace power supply in a PS5. The console is from the first batch, the very first model of everything. I disassembled to confirm that the power supply's model is ADP-400DR.
Obvious choice would be to replace with the same, but given that it died (un- or less- reliable perhaps) and there is a newer 400ER version on the market which seems compatible by size, contacts and screws placement (yet newer 400FR is not compatible for sure).
Is it a good idea, you think, to replace 400DR with 400ER?
Regards,
Sam
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
In this case go with the unit version that was in the console. I’m not sure whether you have the digital unit or the disc / Blu-ray? The failures seem to be from operating temps causing component failures over time? A new firmware could have already have been rolled out (or not) and just make sure to limited idle run time. Make sure there is plenty of space around the console for the fan to dissipate internal heat. The other version is physically compatible but might lack components that limit the amount of power in certain situations. The main thing is not exposing it to extra heat via poor ventilation. Max frame rate will cause a surge in power also. Hope this helps. I’d like to know what you do and how it works out if you can update us?
War diese Antwort hilfreich?
Bewertung 0
Since nobody has put a clear explanation past “use whatever you originally have” here is my observation
The 400er port is closer to the edge of the supply while a 400fr is closer to the middle , so installing the ports won’t align properly
Not sure about a dr so if anyone has better information i would appreciate it
Bewertung 0
2 Kommentare:
That’s because the DR & ER are compatible if you look at the model numbers when they switch to model # starting w 2…… they switch to FR PSU. That is correct the FR will not work in prior models. They also switched from a 17 blade fan to a 23 blade fan during the ER units life. Sony obviously started figuring out it wasn’t firmware that would fix this. I can’t believe Sony gets away with this crap. It’s basically stealing when you all but admit that they put a product out that couldn’t hold up. Sony is still ambiguous about it cause they know class action suits are coming
von
Looking at the FR it’s also got the ports orientated vertically instead of horizontally. I believe you have the DR on the left w the antenna still attached. It’s difficult to tell it’s blurry but it looks like the ports are vertical and the one on the right which is crystal is obviously horizontal. I haven’t seen a DR my ps5 came w ER and 17 blade fan 1115a. All the research I’ve done says they switch to a new fan on this model and then they switch to the FR on the model 2 series which all then started the model #s changing to starting w #2——. Some are also just marked PA-1401-JT20. The FR turns to JT3 at the end. This is probably one of the most confusing purchases I’ve made. So many eBay all have multiple listing of same PSU if you look closely at the seller you can tell it’s a front and it’s china. Literally Rancho Cucamunga CA has auto parts sellers mostly and they all track back to china not the PSU the seller. I know the PSU came from the east. You can tell from the photos they all use the same
von
Antwort hinzufügen
Sam Pam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 37
Letzte 30 Tage: 130
Insgesamt: 4,089
