gear shifting not smooth got stuck every time I change gear
Problem in shifting gears
Ist dies eine gute Frage?
Assuming your vehicle has a hydraulic clutch system then your problem sounds like it is most likely either low of fluid, out of adjustment due to normal wear, broken or collapsed line from the clutch master cylinder to the slave cylinder, or one or both of the before mentioned cylinders has gone bad.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 60
Insgesamt: 128
