My truck don’t what open
To close the truck by pushing the bottom, not what to close. I need to close with my hands.
Ist dies eine gute Frage?
Going on the assumption that the problem is the trunk won't close by pushing the button. VehicleHistory.com has a page devoted to the subject on your SUV here.
Toyota Highlander: Power Rear Door Not Working? - VehicleHistory
Here are a couple of highlights from that page.
- The quick fix for this problem may be to press and hold the rear liftgate close button. It will beep several times and then let go. This will reset the liftgate and allow it to work properly in most cases.
- check the on/off button inside the glove box.
- Locate the close button on the rear liftgate door. It is only accessible in the liftgate door jamb when the liftgate is in the open position.
- Press and hold that button for a few seconds. You should hear it beep about four times.
- Release your finger.
- Then, press the button again quickly to signal to close the door. This should fix the problem and allow it to close normally.
Those are a few things to check. Try out these fixes and let us know what happens.
War diese Antwort hilfreich?
I've tried everything under the sun, nothing seems to work
MOST likely issue is the glove box switch. It is on the upper left side. Open the box and look for it. It is not hard to accidently activate it OFF.
Eh intentado todo eso y no se soluciona el problema
Letzte 24 Stunden: 11
Letzte 7 Tage: 42
Letzte 30 Tage: 177
Insgesamt: 5,328
1 Kommentar
@gitsel Could you please give a little more context and information about the situation?
von LucaBadooka
