Zum Hauptinhalt wechseln
Das am 24. September veröffentlichte Flagship-Smartphone von Apple für 2021 bietet ein 6,1-Zoll-ProMotion-OLED-Display, ein neues Rückkamerasystem mit drei Objektiven und 5G. Es ist der Nachfolger des iPhone 12 Pro.
69 Fragen Alle anzeigen
Is it okay to clean my phone’s charging port with nylon picks?
I’ve had an iPhone 13 Pro for a while and the time has come for me to remove some debris from the charging port. I was looking on Amazon for tools and I found a cheap, disposable set of nylon picks that are made for cleaning firearms but they look like they’d do the trick.
Is that material safe to use for this kind of thing?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would think your little nylon picks would be a good choice. The main things to avoid are metal, so you don't short the pins together while cleaning, and metal, something hard enough to damage the pins. So your nylon picks meet both criteria and will work great.
An eyeglass microfiber cloth and some 90% or higher concentration isopropyl (rubbing) alcohol, along with a nice bright light and magnifying glass would be the other things I'd want on hand. That should get you going; just take your time and be careful and you shouldn't have any problems.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
soupmode wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 42
