Where is the WPS button
Ist dies eine gute Frage?
@ericliddell should be in your settings menu. It does not look like your printer has a physical button. Let's assume you are trying to setup a wireless connection. use the instructions from here You can also download the MG6600 series Manual from here It will help you with your setup.
War diese Antwort hilfreich?
Every printer I've had doesn't use a button, it's always in the network setting. Don't have a demo Canon, but I do it on the HPs from Network>Wireless setup wizard for the screen versions or WPS on some old 2-liner models. My gently used (with a bad imaging drum) monochrome laser uses the app under Network unless you enter it manually or use WPS.
I suspect Canon is similar.
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 31
