Whirlpool LSR8233EQ1 washer will not spin correctly
Hello, I had my transmission break and it was slipping and making a banging noise on the spin cycle. So I ordered a new transmission. After replacing it now the washer agitates fine but then when the motor spins the opposite direction to make it do the spin cycle it will not spin until I open the lid for a second and close it. Then it spins fine. As long as it doesn’t switch to agitation it will continue to spin fine. They sent a replacement transmission and it does the same. Any ideas on what could be wrong?
Ist dies eine gute Frage?
2 Kommentare
Hi @chrishobbs61646,
Does the timer keep advancing when it reaches the spin mode (before you open the lid)?
Does the problem occur on all wash cycle types?
von jayeff
Yes. Everything else works fine. If I don’t open the lid it will pump the water out and continue with the next cycle. Yes it does it on all cycles.
von Chris Hobbs
