Zum Hauptinhalt wechseln
Reparatur und Zerlegeanleitungen für den drahtlosesn Sony WH-1000XM3 Überohr-Kopfhörer mit Geräuschunterdrückung
Right speaker Isnt working.
The right ear cup isnt producing any audio. The swipe functions on it still work when switching songs and pause and unpausing. Also the left ear cup does produce audio. The headphones can charge and the noise cancellation features also still work.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I assume you are speaking of wireless operation. Is it the same with cable? If yes, then It must be speaker problem.
If the rt works with cable, then it is a problem with the internal PCB.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
yes this happens both using a cable and with bluetooth. If its a speaker issue how do i fix it or is it worth buying a new pair?
von
the problems with fixing them is;
1. finding the right part
2. opening up the earphone without breaking something
3. removing/replacing the speaker
4. reassembling
Of course, you probably want to open first to berify the speaker is bad.
If you get a none exact replacement, do you have a critical ear such that you will hear the diff?
von
I appreciate the help, I'm probably going to go to a place and get it fixed there. I've had these since 2019 and I don't want to risk breaking them more. I do really appreciate your help though.
von
Antwort hinzufügen
Abel Mekonen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 149
