Network Not Working even after Reset
I have tried all the troubleshooting ways to try and fix my wifi and bluetooth without touching my phone. I wanted to know where in the phone is the network module so I can buy a replacement and fix it. If anyone knows which part that is and where its located in the phone, I would be greatly appreciated. Thanks in advanced!
Update (02/22/24)
It says Model Name is SM-N986U1
Ist dies eine gute Frage?
6 Kommentare
Hi @kmantilla,
What is the model number of the phone?
von jayeff
@kmantilla it will help if you can tell exactly what "troubleshooting ways" you tried and what you mean by "try and fix my wifi and bluetooth without touching my phone."
von oldturkey03
Sure sorry about not being more detailed in my response. So for troubleshooting I tried all of the common ones which was restarting the phone, restarting the network/accessibility setting in the reset menu, also turning on and off airplane mode, and any other ones that are easy to that I tried doing online. Once that didn’t work I did factory reset the phone and that still didn’t do anything in terms of trying to fix my problem. For your second comment about me trying to fix my phone without touching it, was about me physically not opening the phone itself. I wanted to try all the options until it lead to that. I hope this answers your question!
von Kristopher Mantilla
@kmantilla yes it does. Thank you. I do believe that at this point you have exhausted whatever you can do without opening it. It appears that it might be time to look at the hardware.....
von oldturkey03
@kmantilla
Just clarifying is the WiFi/BT turning on but not detecting WiFi networks or BT devices to pair with or is the WiFi/BT not turning on at all when you try to turn it on i.e. greyed out?
If turning on but not detecting try using the phone as close as possible to the WiFi router or BT device e.g. <10cm and check if it detects and also connects/pairs etc.
Has the phone been dropped or gotten wet at all?
von jayeff
1 weiteren Kommentar anzeigen
