Zum Hauptinhalt wechseln
The Lenovo IdeaPad S145-14IWL is a lightweight and compact laptop built for entry-level laptop users. The IdeaPad is affordable and robust, amazing for office work on the go.
What form factor is the SSD in this laptop?
I am looking to upgrade the ssd in this laptop and I would like to know what size M.2 drive it has. Is it a 2230 or a 2280 for example?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @timothyhoyles
The form factor is M2.2280.
Here's the hardware maintenance manual for the model.
Go to p.45 to view the procedure to remove/replace the M.2 SSD.
If you wanted to and if you haven't already done so you could also replace the HDD with a 2.5" 7mm sata SSD (up to 4TB). Ensure that you get one that comes with a 9.5mm spacer that is placed beneath the drive so that it aligns correctly with the sata connector on the board
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
timothyhoyles wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 122
