Zum Hauptinhalt wechseln
Pages for the HP Pavillion e-series of 15-inch laptops, with either an 11th-gen Intel processor (15-eg) or AMD Ryzen 5 (15-eh) configuration. Released in 2022.
How many internal memory slots are there? 15-ec2097nq
I want to upgrade my memory in my HP 15-ec2097nq to have a higher capacity m2 ssd. And probably an hdd for bulk files (photos, videos, large files, etc.). How many m2 /sata slots are there? And what are the speed limitations. Thank you in advance,.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @redill
The laptop supports up to a maximum of 32GB DDR4-3200 (PC4-25600) sodimm memory over 2 slots i.e. 2 x 16GB modules.
There is one M.2 PCIe 4.0 socket which takes an M.2 2280 NVMe SSD (up to 2TB) and you can also replace the existing sata HDD with a 2.5" 7mm sata SSD as well (up to 4TB). If you decide to upgrade the HDD to an SSD ensure that the SSD comes with a 9.5mm spacer, which is placed under the SSD so that it raises it to the correct height to align with the sata connector on the board.
Here's the maintenance and service guide for the laptop series that may help.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you, really appreciate that.
von
Antwort hinzufügen
Redill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 41
Insgesamt: 220
