Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
What is the difference between GSM and CDMA model internally?
What parts are the same between the two models internally and what are different?
When I am repairing someones phone what parts can be interchanged between the two and which can not?
Is the LCD/Digitizer the same?
Does the back have the same brackets?
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
Both iphone4s has a same Back panel brackets.
von
you guys are not reading the question. Not asking about iPhone 4 at all! only the new versions of the iPhone 4S. What are the part differences. I do not worry about the differences between iPhone 4 and 4S.
von
all the phone4s are same ... you can change anything from one another got it.
von
Einen Kommentar hinzufügen
8 Antworten
Hilfreichste Antwort
there are 2 types of iPhones. iphone4 CDMA looks like iphone4s from inside and outside but this does not support sim card. there is no space where you can put the sim card.
iphone4s are also again 2 types.
1 is GSM phone and other is CDMA+ GSM. other one also known as world's phone. you can use both GSM sim and CDMA service in this phone.
the parts are almost same as all in these 3 phones. all are same just difference in logic board. you can use any part from these for interchanging to checking the working condition.
War diese Antwort hilfreich?
Bewertung 2
There are 3 types of iPhone 4S manufacture configs.
GU_US, GSM/UMTS USA/Asia variant
GUC_US, GSM/UMTS/CDMA variant
They are completely identical in hardware, but the GUC ones are provisioned with CDMA baseband data, that's the only way to use CDMA.
The third one is GU_EU, most parts are identical, with slightly different top antenna to pass European RF regulations
Bewertung 1
LCD/Digitizer are identical and so are all of the other parts. The only exception, of course, is the logic board.
Bewertung 1
What about the Bezel. It is not the same but are the screws for the lcd/digitizer in the same spots. Do you have to keep a stock of CDMA and GSM? Are they different. I know the battery, vibrator, cameras, loudspeaker module, charging port, home button and home button flex, are the same.
Bewertung 0
1 Kommentar:
I have a world phone which is CDMA from Sprint but also has a GSM portion. Now i m using GSM SIM in this phone. the bezel is same for the iphone4S only. iphone4 CDMA has a different Bezel becoz we cannot put the SIm inside. there is no space for sim. the both IPHONE4S CDMA and GSM phone are same . screw locations are also same.
von
CDMA- No sim card support, Can only use it on a carrier.
GSM- Sim card support, Can use it with other sims.
Bewertung 0
1 Kommentar:
I have iphone 4s (CDMA) but I cant use it in Ghana. please help me.
von
Look I have a Verizon phone with a sim tray so is it the same as others iv seen Verizon's phones with no tray those most be the older ones right
Bewertung 0
1 Kommentar:
Yes those would be iPhone 4 and not 4s.
von
I don't have an answer but I am working on iphone 4 and recently bought some logic boards but they are longer than the one I am replacing. So whatz up with that? Anyone
Bewertung 0
The LCDs are the same size but the frames are different. if u can change this frame, u are good to go
Bewertung 0
Antwort hinzufügen
SaqibQ wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 18,735
