My phone is not charging but charger working
While I connect to the charger my phone is not charged
Ist dies eine gute Frage?
@vaishnavidevi could be a bad battery, bad charging circuit or a bad charging port. Having run into this a lot over the last few month, the easiest is to actually replace the charging board. It is relatively inexpensive and replacing it is fairly straightforward. Also, check the flex cable from the charging board (sub_board) to the main board for any tears corrosion etc. Once you have the board replaced I would also replace the battery, since you have the phone open. That way you only have to do that one time.
Since ifixit does not yet have a guide for that, use something like this video to replace the parts.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War one Entropy
War diese Antwort hilfreich?
Hello I changed bord and battery but still not charging what I need to do now help me please thank you
@gabrielgab45028 did you check/replace the flex cable from the charging board to the main board?
How it's look 😁? Flat one or thin one
I think it's flat one just ordered to change 😉
gini loh bro kawan kawan
saya punya hp poco x 3pro udah lama dan masalah ini bukan dari flaxsibel ataupun papan board pengencesan harus ganti baru, intinya yang rusak itu ic pengecesan yang ada di board mesin
@vaishnavidevi, In my case it was a loose connector. Remove the back cover and check the cable which connects the charging port with the mainboard. You need to remove the cover of the mainboard around the camera to reach the connector. For details, see the tutorials, e.g. for changing the battery. It shows all the necessary steps.
Good luck!
Hello, my friend, the problem with your phone is probably from the charging socket or it is dirty and turn it off and on again so that it might be fixed, then clean your charging socket.
Battery Is weak or Charging port dead
Letzte 24 Stunden: 5
Letzte 7 Tage: 42
Letzte 30 Tage: 177
Insgesamt: 8,779
3 Kommentare
Hp tidak mengisi
von Wardin Tolinggi
@wardintolinggi follow the instructions from my original answer. Let us know what you find out.
Translate
@wardintolinggi ikuti instruksi dari jawaban asli saya. Beri tahu kami apa yang Anda temukan.
von oldturkey03
Not work for charger put not working
von Hindi movie 55
