Green + red + yellow cause strum
Hi, having an issue where pressing the first three frets at once causes a downstrum. When I hold these frets, I can still strum up after the first downstrum has happened, but strumming down has no effect.
I have already resoldered the neck connector pins and have even gone as far as to completely unsolder the entire 14-pin strum bar connector from the "main" board, the one with the Xbox button. As far as I can tell, none of the connections on that 14-pin board are shorted to the one next to it and I've run out of ideas.
What could I do next to try and pinpoint the problem? Has anyone fixed an issue like this on their controller?
Ist dies eine gute Frage?
1 Kommentar
Issue actually fixed here: https://www.reddit.com/r/GuitarHero/comm...
OP here soldered signal diodes between certain connections to resolve the issue.
What I posted before did not work.
von Martin V
