Help please reference codes, PPN001 y PFM006
Hello, how are you? I want to describe my problem and hopefully someone has the same one who could solve it and could tell me what the solution was in advance, thank you very much, the case is as follows, I have a macbook pro mid 2017 A1706, recently its battery stopped working The cycles were exhausted, I changed the battery, but everything was fine, I removed the previous battery, placed the new one, I closed the MacBook and turned it on, but now it takes a horrible time to start and everything became extremely slow, I performed a fault diagnosis. hardware and the result was the following with these 2 codes
PFM006: There may be a problem with the System Management Controller (SMC).
PPN001: There may be a problem with the administration system
I returned the previous battery thinking that the new one was the problem, I reset the (SMC) using the keyboard combinations, but it didn't work, in fact it doesn't perform the reset function, can someone tell me if it happened and how I solve it , someone please
Ist dies eine gute Frage?
