Zum Hauptinhalt wechseln
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
20 Fragen Alle anzeigen
I Swapped the Trigger and Bumper Ribbon Cables
I swapped the Trigger and Bumper Ribbon Cables with new ones and now the controller doesn't power on. If I disconnect one of the t&b cables (L1/L2) and leave the other one plugged in (R1/R2) the controller powers on and R2 and R1 work. I'm confused as to why this happens. Any help?
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
What if you disconnect the R1 & R2 cable? But leave the other one connected, does it still power on?
von
No it does not
von
Any solution??
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Have you doublechecked that the triggers match up with the points on the controller responsible for registering input? If not do that.
There should also be a spring in the buttons. Is this connected correctly?
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Benji Customs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 74
