Why ongoing calls hang up when Speaker button pressed?
With our CL4940 during an ongoing call, pressing Speaker and placing the handset in the base hangs up the calll, even though the instructions say this is what to do. Do you see the same issue? Or do you know of any workarounds?
Ist dies eine gute Frage?
1 Kommentar
Hi @bkengland,
Can you make an outgoing call OK when leaving the handset in the base and pressing the Speaker button and then dialing the number?
If you can, what happens when the call is established and you converse through the speaker and you lift the handset, does the call drop out or do you have to press the Speaker button to continue hearing the conversation in the handset earpiece speaker?
von jayeff
