Zum Hauptinhalt wechseln
Veröffentlicht am 16. Oktober 2014, Modellnummer A1347 - EMC 2840
Mac Mini 2014 missing bottom cover. is this a problem?
I have obtained a mac mini 2014 that is missing the plastic bottom plate cover. Is this a problem? Does this block airflow, and if so, would this be mitigated by adding feet to the base of the mac to give raise the device a little to allow air circulation? are there any other issues that will need to be worked around?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I'd recommend adding the feet onto the Mac as it would allow for improved airflow into the device. But other than that I don't think it should be too much of an issue.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
It might be just worth the expense to replace it here's the needed part Mac Mini Bottom Cover (used) $11 USD
von
Thanks Dan. I had searched for these online but had not found one with reasonable postage to Australia. I have bought this one as both the price and postage were reasonable.
von
Antwort hinzufügen
James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 261
