Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für LG Smart TV. Hier findest du alles, was du für deine LG Smart TV Reparatur brauchst.
20 Fragen Alle anzeigen
Picture blinks on and off but the sound is fine
Picture keeps coming on and off but the sound is fine,is there a replacement board to fix the problem?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Hi @waltthompson,
What is the model number of the TV?
Can you view the TV menus OK without the screen blinking?
von
Flickering on an LG TV could be caused by various factors. It might be due to a loose cable connection, a malfunctioning power supply, or even a software issue. To diagnose the problem, I recommend checking the cable connections first and ensuring they are secure.
von
Einen Kommentar hinzufügen
1 Antwort
@waltthompson you are not giving us much to work with here. We do need to know what model your TV is. Returning a quick and dirty answer based on the information we have, this is not a board issue but a backlight issue. Your strips are turning off, cooling down and then coming back on. Replacing the backlight strips will resolve this. Sometimes you can determine if it is the strips by decreasing the brightness of the screen. If you set it to 50% or so and it stays on longer , you know it is the strips.
Now, this answer may change if more information becomes available.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Walt Thompson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 63
