Zum Hauptinhalt wechseln
Why is my phone unable to switch on and it stopped charging as well
I switched off my phone at 17% at 10:49pm yesterday night being a Friday.
I woke up at 15 minutes to 6 the next day and I tried switching it on and it wasn't responding,I tried charging it as well and it still didn't work out... despite it being a new phone... please help out 🤲
Ist dies eine gute Frage?
Bewertung 14
5 Kommentare
Why thus is hard
von
Mengapa hp saya selalu tertekan sendiri beralih tidak karuan
=== Update (07/23/24) ===
Kenapa hp saya selalu tertekan sendiri
von
@solihinahmad does this only happen when you try to make a call? does it happen with other Apps as well?
Translate
@solihinahmad apakah ini hanya terjadi saat Anda mencoba menelepon? apakah ini juga terjadi pada Aplikasi lain?
von
Yes it's happened when I make calls
von
Why my phone not charging I will check new charger then my phone was charge only 2/3 day working then again coming same problem not charging
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
@knightdml try to force a restart and press and hold the power button for at least 8 seconds until the Android logo appears. After that you want to check your phone charger and your charging cable and see if that has the proper voltages as well as no bend/broke or corroded contacts. Check your charging port to make sure there is not debris in it that prevents proper charging.
Since this is a new phone, you do want to return it to wherever you got it from. It should still be covered under warranty and there should never be a reason to repair it yourself. Unlike good cheese, phones will never get better with age ;-)
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
My phone the is to low
von
The phone, even when turned off is still running apps on its system and that would be why it went fully flat (discharged).
A new phone and charger should be working but strange as it sounds, this is quite common. Most of the time it is because the charger is not plugged into the mains power supply properly, please check the power plug is also turned on from the wall socket as well.
Bewertung 1
OTG means On-The-Go and allows a phone to connect USB devices
Bewertung 0
  • OTG means On-The-Go and allows a phone to connect USB devices
Bewertung 0
Antwort hinzufügen
Knight DML wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 2,807
