Zum Hauptinhalt wechseln
Released October 2013, model number: ZHN.
Is there a way to upgrade the SSD?
Hi!
I am looking to upgrade the SSD from 16GB to at least 32GB for my Chromebook that I use Ubuntu on. I need help looking for SSD's that would fit into this Chromebook, as this Chromebook uses a small SSD that I can't find in a bigger size.
Can you guide me in the right direction to find a bigger SSD that is the same size but holds more in storage?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@jri_creator it uses a SATA 3 M.2 (NGFF) SSD and it is 42mm in length, better known as 2242. M.2 SATA 2242 ssd are readily available at many online stores with way more than 32GB for not a lot of money.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jri-creator wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 121
