Zum Hauptinhalt wechseln
The Dell Chromebook 3100 2-in-1 was released in 2019 and can be identified by model number P30T001.
How to replace storage on the Dell Chromebook 3100 2-in-1
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
@li2 the 3100 uses eMMC storage which is soldered to the motherboard and it is not replaceable.
Update (04/07/24)
@li2 not on the Chromebook just on the card. Check the Dell Chromebook 3100 2 In 1 Service Manual toward the end it tells you how to do a reset and recovery. Hope it'll answer all of your questions.
War diese Antwort hilfreich?
Bewertung 0
8 Kommentare:
@oldturkey03 is it possible to unsolder the eMMC storage and replace it with a new one or it wouldn't work because the system wouldn't recognize it
von
@li2 it does not work that way. It's a different IC's then what you might be used too.
von
@oldturkey03 can you use a sd card and install chrome os on that would that work
von
@li2 it's got the card reader that you can (must) use to install your OS, so I do not see why it would not work. Just use a large enough card and go for it :-)
von
@oldturkey03 Thanks for letting me know but do you have to wipe the memory first on the Chromebook for sd card?
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
li2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 46
Insgesamt: 526
