Zum Hauptinhalt wechseln
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Fragen Alle anzeigen
Why don’t my car has no spark
Why is my car as no spark
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Have you tried to replace the battery?
von
Einen Kommentar hinzufügen
1 Antwort
This vehicle had a recall on the Cam Position Sensor. Which typically throws a 0340 DTC Code and will prevent spark at the plugs. I would start with pulling the codes from the computer and verifying that your car is not part of the original recall and never got serviced otherwise my first inclination is that it is the crank position sensor which is known to cause this issue.
I hope this helps out a bit.
Cheers!!
Moe
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Bryan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 64
