Zum Hauptinhalt wechseln
Das am 16. September veröffentlichte "kleinere" Flaggschiff-Smartphone von Apple verfügt über ein 6,1 Zoll ProMotion-OLED, ein rückwärtiges Kamerasystem mit drei Linsen, 5G und eine neu gestaltete Dynamic Island um die Frontkamera und die oberen Sensoren. Es ist der Nachfolger des iPhone 13 Pro.
20 Fragen Alle anzeigen
Possible to change logic board bcz of activation lock?
Is it possible to change logic board 14 pro bcz of activation lock no opetion to unlock plz guid me
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Ihave iPhone 14
My divice is icloud locked
How to unlock
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
If this is a phone you purchased, you will have to have the previous owner contact Apple or remove the phone from their account. Otherwise if you are the original purchaser of the phone, then you can contact Apple and with the proper documentation they can remove the iCloud lock.
If you can't do either of those things, then I'm afraid you are out of luck. There is no way to forcibly remove an iCloud lock.
von
Hilfreichste Antwort
Sadly Apple's policy of parts pairing has only gotten worse over time, to the point where the iPhone 14 is one of the worst phones on the market in terms of repairability. And that's not because of the mechanical design; they originally got a score of 7 out of 10 for repairability, but after examination of the parts pairing done to the phone, iFixit dropped their score down to a 4 for the simple fact that many parts will no longer work after being replaced. Here's the article I'm referring to.
We Are Retroactively Dropping the iPhone’s Repairability Score
What that means for you is that swapping out the motherboard means that a large number of functions on the phone will simply stop working. Face ID will be disabled, True Tone will no longer function, you won't be able to see your battery health, your selfie camera can't take pictures, wireless charging won't work and your taptic engine may or may not still vibrate. Here's a chart listing all of the parts pairing Apple has done to the various models of its phone.
So basically you would have to buy a replacement motherboard and all of its paired parts if you want everything to work. Unfortunately, that means you now need most of the interior components of the phone, so there's no point in swapping a motherboard when you need everything else as well. Apple has made sure that swapping a motherboard is no longer a viable solution for getting around an iCloud lock.
Sorry I don't have better news for you, but I'm afraid you're in a bad situation. You can't get the lock removed, and you can't use the phone for parts, so it's basically an expensive paperweight now.
Bewertung 1
2 Kommentare:
Well I think iFixit can split the repairability score into multiple dimensions, like mechanical repairability, parts and documentation availability, software locking and maybe durability to see if it is too easy to break in the first place.
von
@tomchai Not a bad idea, Tom. You should bring that up over at the Meta site.
von
Antwort hinzufügen
Mohammed asrar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 184
