Zum Hauptinhalt wechseln
Eine kleine Überarbeitung des MacBook Air von Ende 2018 mit gleicher Modellnummer (A1932) und EMC Nummer (3184). Dieses Modell ist mit True Tone und einem leicht abgeändertem Akku ausgestattet.
Overheating Problem that doesn't go away no matter what I do :(
Hello! I'm trying to fix an 1932 Macbook Air from 2019, but I've been struggling with overheating. It heats up to 90-100 degrees Celsius on startup, then goes down to 30-45 on idle, after the fans sit in full blast for a while.
Whenever I do anything on it (like open a file) the temp immediately jumps up to 60-70 degrees Celsius.
Whenever I start a graphically-intensive process (like open a PDF with images, launch a browser, open multiple images, etc) the temp quickly jumps to 80-90 Celsius.
In both cases, it needs the fans running at 8000 rpm for like 10 seconds to cool back down.
I'm using Macs Fan Control to monitor the temperature, and I set my own automatic rules for the fans to kick in earlier.
Even so, the computer often goes into kernel panic due to overheating and restarts (can't use it for more than 1 hours without this happening). I can provide the reports if you think it'd help, the only common thing between multiple reports I've noticed is that the process responsible is usually kernel_task, though I'm not sure that adds anything.
Here's what I tried so far:
  • Cleaning the insides of the laptop, fans, etc, it's spotless in there.
  • Replacing the thermal paste.
  • Resetting device, and reinstalling macOS
  • Resetting the SMC
Replacing the thermal paste had an impact, it lowered the idle temperature from 40-50 to 30-45. But I still get the kernel panics.
Considering all the symptoms, What would you think is the problem? I can't notice any damage or problems around the CPU/GPU, and since the laptop functions, always gets past POST, etc, I'm not sure if it's a motherboard issue.
I was thinking the fan might be the problem, but that too looks fine on visual inspection.
My last recourse was to change the battery - I was thinking there might be a problem with its board, sending too much power to the GPU? Is that possible, should I consider it?
PS: Nothing comes up while doing Apple's diagnostics. Problem persists in safe mode, with no peripherals connected.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
My intel i5 processor macbook pro from 2019 got the same problem.
von
Einen Kommentar hinzufĂĽgen
1 Antwort
Gewählte Lösung
unfortunately this is the way A1932/A2179 is designed. Your CPU is slightly degraded now, so it generates more heat. Putting a big thermal pad on top of CPU heatsink to + removing plastic sticker on bottom plate will reduce temps by 20-30C, however you will have very hot spot on your back cover.
Other option would be to try to find a dead i7 logicboard, they had better copper heatsinks.
In both cases keep your data constantly backed up / clouded, next step is usually a dead CPU.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you! Will try this and come back to update on the results. Do you think a thermal pad + copper shims will have better results? Like they do here: https://forums.macrumors.com/threads/202...
Do you have any recommendation for thermal pads/shims?
von
well, i used some random pads which came with SSD drive and it was able to keep CPU under 85C under full load (i also adjusted macsfancontrol to keep CPU under 95C
von
My 2020 1.1ghz i5 Air was ramping up to 200-210 degrees F so I followed suggestions to place 15x15x3mm copper shims (one shim cut to fit) and heat is down to 175 degrees when running videos, no more throttling either slowing machine down. Light use has temps down from 175 to 120-135. I cleaned old crappy thermal paste off, then high quality thermal paste directly on the cpu and gpu, then paste on the shims and placed these in the heatsink, put heatsink back in place and voila, temps that now make sense.
von
Antwort hinzufĂĽgen
TheoP wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 35
Letzte 30 Tage: 124
Insgesamt: 2,671
