Zum Hauptinhalt wechseln
Der Kindle Paperwhite 2 wurde Ende 2013 freigegeben. Das Gerät hat ein 6 Zoll Display, 84 Pixel pro Zentimeter, drahtlose Verbindungsmöglichkeit, und eine 28 Stunden Batteriekapazität.
Wifi - connects but immediately drops connection
In settings -> wireless -> wi-fi networks -> choose my wlan and enter the password:
Kindle connects but drops the connection in about 10 seconds.
Notes:
  • local library OK; date & time correct; all functions appear OK except wi-fi connectivity
  • no error message
  • no error report in the router log
  • other devices on the same wlan have no issues
    • called Amazon support
  • on instruction from Amazon support, did a factory reset - didn't fix the problem
  • tried connection to a hot-spot using my mobile phone - same result
Guess I'll have to buy a new one? Would like to troubleshoot it myself though. Any help/guidance appreciated - Steve
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
when the connection drops, a new window opens to enter connection details for connection via the "experimental browser" - this results in "500 internal server error"
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Before giving up completly you can try as your last resort to check for software updates, it might seem stupid but also try to Restart your router.
You did most of the things I would have done, so if that doesn't work you're right again, you'll have to buy a new one.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi, great suggestion which has led me to the issue.
* hard restart (power disconnected - 30 seconds) router restarted
* kindle connects OK (with IPv6 enabled)
* because I'm using a smart DNS service, I have to disable IPv6
* Kindle then drops the connection
This never happened before so I'm guessing, a recent amazon update has changed something????
von
Antwort hinzufügen
Steve G wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 473
