Zum Hauptinhalt wechseln
Die Xbox Series S ist die aktuelle Konsole von Microsoft, die ohne Laufwerk auskommt. Sie wurde mit ihrem großen Bruder, der Xbox Series X, am 10. November 2020 veröffentlicht.
Xbox series s turns off 2 seconds after I turn it on?
Why does my xbox series s turn off about two seconds after I turn it on with no display I think it could be the ssd do I need to buy a new on if so were do I get the xbox os from.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
@braydenc what makes you think it is the SSD? What have you checked?
von
Einen Kommentar hinzufügen
1 Antwort
It seems like your Xbox Series S might be shutting down due to an issue with its SSD. Try these steps:
  1. Check all cables for secure connections.
  2. Perform a power cycle by unplugging for 30 seconds.
  3. Consider a factory reset via Settings > System > Console info > Reset console.
If the issue persists, you may need to replace the SSD.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
@tabathakang AI, got a question for you. How do you suggest to perform factory reset if the xBox does not come on? AI would not check anything else but would go right to the SSD? Why? AI can't think for itself and uses regurgitated Google stuff :-) Start using your own brain (algorithm). LMBO so weak and predictable.
von
Antwort hinzufügen
Brayden c wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 374
