iPod only shows power adapter being plugged in to wall outlet?
My iPod will not do any thing, when charge/sync cord is hooked up it will only show a power adapter being plugged into a wall outlet. I cannot get the click wheel to do anything, and when plugged into my PC it does not recognize that I have it hooked up. I have tried changing cords but still no luck. any sugesstions
Update
I have done all of the suggestions and still my 20GB Classic will not go and I have the "power adapter plugging into the wall" sign showing..help this iPod was for grand daughter for xmas..her first.
Ist dies eine gute Frage?
4 Kommentare
Just in case :) sometimes after an iPOd gets updated by using an USB cable, and after the iPod reboots, it gets stuck on the "plug in to wall" icon and won't go any further. I would try try a FireWire cable rather than a USB one. Plug the FireWire cable into the wall charger the first time and the update will usually complete successfully.
It would seem that the crucial thing here is to either:
1. Use a wall charger with either a FireWire or USB cable.
OR
2. Use a FireWire cable to connect your iPod to your computer if you have a FireWire connector. Again, I think we need more info to help you out.
von oldturkey03
This should verify it. The iPod wants to be plugged into a power outlet and won't proceed until you do so. You see this icon after you've restored your iPod and the iPod needs to update its firmware. This occurs only when you've plugged your iPod into a USB port or un-powered FireWire port (the 4-pin variety of FireWire ports found on some PCs).
von oldturkey03
Gloria, use a wall charger not your PC
von oldturkey03
I can't seem to pull the charging cable from the bottom of my old iPod touch
von Carl Closset
